Hi
I wondered if anyone else is having trouble getting lamps (bulbs) to fit the warning light cluster?
I bought 10 lamps (LLB280 T6.5 12V 1.5W) from a vendor on eBay and tried to fit them. Although the same diameter at the thread end, the inner thread to the Edison Screw seems too large to engage into the holder. I thought that maybe the lamps were not to the correct specification.
I then bought 10 lamps -Genuine Lucas LLB280 12V 1.5W E5 (I thought that it should be ES) and went through the same procedure - with the same results. The lamps still will not screw into the holder. I dont need to replace all, but I was going to!
I did read a previous on replacing most with LED's but it is not a simple one for one process. I might have a go in the future as I have replaced nearly all my lamps - except these, the indicator and the headlights for LED. The LED's make a huge difference.
Grateful for any ideas or advice.
