carburettors are losing oil - is this a common problem ?
    Evening all
    The stag had its mot last Saturday and also had the oil in the carbs topped up as they were dry and causing running issues.
    Anyway took it out again last night and the same issues had returned and the carbs are dry again. The diaphragms were both checked and are ok.
    i don't really understand the make-up of the carbs and am not too sure what / where to check first.
    Any suggestions please
    thanks
    Dazza
    Dazza,
    Inside the carb pistons are the needle carriers. These have small o-rings to prevent oil loss. Your have no doubt gone hard and are leaking. It is a fairly straightforward job to replace them.
      Thanks dave - would it be these from ld parts ? I would rather get them before I take the carbs apart
      Carburettor Compensator Seal Small 516971
      £1.47 INC VAT
      Carburettor Compensator seal Small Size
        No, those are for the temperature compensator. These are the ones:
        They fit on this part:
        Pages 51 & 52 explain the job
          this may help it's the seal as Dave said above the needle on the brass thread screw, hope this is helpful.
            Thanks guys - that article is just what I need. It mentions a needle adjusting tool - is this something special/essential or can it be done with a more common tool ?
            dazza
              This device is used on adjustable Needle (top Adjustment) Carburettors of the CD type. After removal of the Damper unit from the carb top the tool is inserted into the Damper resevoir. The central Allen key locates in a Socket in the resevoir Base while
                dazza
                Dazza - essential. The tool turns the needle adjusting screw (with an allen key) whilst stopping the airvalve assembly from turning (which can rip the diaphragm).
                  Thanks for all the comments so far, thanks to Peter at ldparts I now have the tool and the seals as described above in super quick time. One last question before I try this the article talks about the needle returning to its datum position, and I'm not really sure what that means. Essentially if I take everything apart am I am able to simply put it back again without needing any knowledge about adjusting the carbs ? Or in other words does removing these parts upset the running of the engine, the reAson I am nervous about it is the fact of needing the adjustment tool - I don't really want to adjust anything, I just want to get at that seal.
                  it might make more sense when I open it up but I do like to have an idea of what I am doing before I start !
                  thank you
                    Darren,
                    If the carbs are adjusted fine now, then the best thing would be to check where the Delrin washers are relation to the bottom of each piston. They should be flush, or close to it. When you reassemble, adjust the needles so that they return to the same position. The manual explains how to set these up as a base setting (flush) then adjust either way to get the correct mixture. It isn't difficult, but if you aren't happy having a go, I'm sure there will be someone close who will help.
