I wanted to ask the advice of others who have faced similar decisions with engine rebuilds of tired engines. If money / marriage was no object, it would be clear cut decision. I've got my engine in with C K engineering who are respected locally in Wycombe area. The heads are off and the it looks like it does need a re bore.
Is the cheaper option of putting new head gaskets on and cleaning up heads a waste of time? I'm being quoted £800 for this option, skimming heads, new gaskets, tidy up and decoke / reset values versus £2.5-£3k for a complete rebuild, which should be good for another 60k+ miles. I'm keen to keep the car for the next five plus years.
If I go for the rebuild root, I guess a new clutch is advisable and crack testing the crank. Also, moving onto getting the engine back in the car, a new header tank is worth doing I hear. Also, one of the adjusters on my carbs has seized so might need a clean. And has anyone tried the waterless coolant available? Are there other things I should consider which would enhance the performance and behaviour of my Stag?
cheers
Giles
cheers
Giles
