Hello,
yesterday I had a short run (25 miles) back from workshop to home. When I parked the car in the garage, I noticed a strange smell. During my investigations I noticed that the right brake drum and the rim of the wheel was very warm, while the left brake drum was still cool.
I jacked up the car and found the right wheel turning with a scratching noise. I removed the right wheel just to find one of the screws missing which normaly retains the brake drum.
Also the brake drum had a small crack.
I checked and cleaned the brake inside, but didn't find the reason why the brake doesn't open completely.
After reassembling the brake the wheel turned freely (even after pressing and releasing the foot brake).
So, here are some dumb questions:
- Is the missing screw critical? Then the wheel is mounted the brake drum will be fixed by the wheel.
- What is the sizing of these screws. The usual suppliers don't mention the size and I don't want to pay the five times value of the screw for the postage.
- Would you replace the brake drum and if so, are there any preferred suppliers?
- Do you have any suggestions why the brake did not fully open? Can it happen using a badly adjusted hand brake?
Each suggestion will be appreciated.
Gerd
Gerd
