Warning: Trying to access array offset on value of type null in phar://.../vb/vb.phar/bbcode/url.php on line 2 Notice: str_replace(): Passing null to parameter #3 ($subject) of type array|string is deprecated in phar://.../vb/vb.phar/string.php on line 3 Spark plugs? - Stag Owners Club Forum
Spark plugs?
    Spark plugs?
    Would anyone recommend me some spark plugs?
    I bought by Rimmer Brot, and after a test, they are not identical in the test.
    When I load the engine, there will be some releases.
    I use NGK BP5E from LDParts
    Mark
    1972 Mk 1 - Sapphire Blue; Original TV8; HID Lamps up front;
      Try these;
      http://www.sparkplugs.co.uk
      No connection with company, etc.
      TBO
        These are the ones you want:
        Just changed mine after 18,000 miles. They were still fine, as are the replacements.
          I am interested to know what the problem was with these plugs? Do you mean that the engine misfired under load? That might be HT leads/rotor arm/distributor cap/coil as well as plugs.
            I was advised to use a slightly hotter plug with unleaded fuel and set the timing to 12 deg BTDC so my car has BP4ES plugs at 0.025", I've noticed the exhaust colour is a lot closer to the light grey that we used to see with leaded fuel using these plugs, rather than the smutty black that I saw previously. No pinking and I get a nudge over 30mpg with a manual o/d box.
            regards,
            Raoul
              click on the black/white little arrow and you find the NGK spark plug for the Stag.
              And a lot more interesting facts to read on the NGK website.
              Klaus
                +1
                I bought champions from here to replace NKGs
                and it seemed to run a little better.
