Ok so I have rebuilt my water pump. New shaft, bearing  and ceramic seal from LD Parts, Machined the impeller to give 2mm preload on the seal - ended up with 4.5mm deep recess in impeller. So far so good.
Have just fitted the pump to the block, measured the gap under the cover - 10 thou (ish). Opted for 30 thou gasket to give approx 20 thou running clearance. Then I fitted the new jackshaft - also from LD parts. Now the jackshaft will not rotate - well it will but it is very notchy - the gears are not meshing correctly. Put the old jackshaft in and still the same - thus ruling out a dodgy new jackshaft.
Removed the pump, removed the impeller, and refitted without the impeller to make sure the cage was seated properly, it was, and the gears still won't mesh. Removed pump and fitted the remains of the old pump shaft (I cut it down to use as a mandrel to machine the impeller). This meshes fine with both jackshafts. Finally I played around with the new pump shaft and jackshaft outside of the engine and they do seem to mesh ok. I think the pump shaft is sitting too high.
Question is how can I adjust it??
Should the shaft come flush with the top of the impeller?
Should there be a washer under the Left Hand thread bolt?
Anyone else ever had this problem?
(please don't suggest I scrap it and fit an external pump - tempting though it is). I want the car back on the road for Brands Hatch next weekend.
Any help or suggestions on what to check to find the problem gratefully received.
