Hi, sorry its not stag related...
I have a mate with a MG BGT which has a misfire issue.
The car will run perfect for approximately 30 minutes till it gets hot then when the throttle is pressed it will miss badly, at constant revs and throttle it will still run fine until you ask the engine to accelerate. This gets slowly worse sometimes resulting in total cutting out of the engine. Leave it to cool and it will start and run fine for another 20 minutes or so.
We have worked through everything basic, and tried new parts such as coil, lunenition module, fuel pump, fuel lines, filter, distributor cap etc and the only two things we haven't looked at are the carbs and the distributor its self.
Upon removal of the carbs we found that one float was 1mm proud of the float chamber face and one was 3-4mm proud whereas the should really be 1mm (+/-0.5mm) recessed from the face.
My first question is would this huge difference cause the symptoms above?
Also is there anything in particular to look at in there that may be causing the problems?
Any thoughts at all would be much appreciated.
James
James
