You might remember my recent "I give up" thread mix of electric and fuel problems. Well today I have found out a big contributor to the fuel issues -I discovered a leak from the electronic SU fuel pump - out of one of the screws that joins the black cover to the silver baseplate. I took the roe halves apart but no obvious diaphragm or gasket leaks. Presume there is a failure elsewhere.
So I will order a new fuel pump - but which one would you recommend and why? Another electronic, an original SU manual or is there another alternative that doesn't need different plumbing? One point to consider, I've had occasional airlock issues with the failed pump and the previous manual one.
All views please!! Many thanks
