Electrical help required please
    Why o why did I touch it !! ?
    Took the opportunity to replace the cluster light bulb for the main beam which hasnt worked since I had the car back, that went fine but as I was removing the dash instument panel I noticed that the door lights went out.
    It turns out the door lights, footwell lights on both sides, the T bar light and the hazard warning switch now do not work - however the indicators are ok on their own.
    Has anyone any ideas as to what all of these run through behind the instrument panel and where I should look first. There are no obvious loose/unconnected wires.
    Many thanks - I may just stick to polishing it!!
    Darren
    Have you checked the fuses ? It could have blown one . The Interior lights and hazzard are all on a permanent feed .
      I think blown fuse. Always disconnect the battery when removing the dash, or any other electrical panel.
        Check the fuse connections for corrosion too. I have had things fail due to this in the past.
          Thanks all for your advice. Turns out it was the fuse in a roundabout sought of way.
          The fuse had blown, I replaced it and it blew again. Then I remembered reconnecting the clock while I had the instrument panel out. The clock didnt work and I had assumed it had something to do with the damage to the front when I had previously hit it with a hammer ! Dont Ask !
          Anyway there must be something more wrong with the clock which is why they didnt connect it when the car was rebuilt,as that is what was blowing the fuse.
          I assume I cant just put a 35amp house fuse in ! lol Look like its a trip to Halfords tomorrow ....
          Thank you
