Hi all
I cant remember if I have asked this question before and am too lazy to search!
Has anyone fitted a combined water temp and oil pressure gauge, if so how easy is it and where is it connected to engine to gain readings, are the fittings required easily available or does the whole thing come as kit . I have located a couple of places where I can get the gauge.
Sorry if I have asked this before but any help will be appreciated
Mick l
.Has anyone fitted a combined water temp and oil pressure gauge, if so how easy is it and where is it connected to engine to gain readings, are the fittings required easily available or does the whole thing come as kit . I have located a couple of places where I can get the gauge.
Mick l
hi mick , easy job . if you buy a kit it may not have the adaptor to connect to cyl head but speedographrichfield supply for about £10.connect in usual way via t piece to oil press switch,then remove temp sender unit from head and fit adaptor and fit cappillary device route pipe along top of bulkhead under bonnet lock and coil any excess .do not make it a tight run.fill and bleed away you go use original lamp for back light. takes 1hr and 6mins including a cup of tea.
cheers steve
