To be honest as the back of the pads had like a small ruberised mat on the back, I had no intention of putting CS on them but only did it as the sachet came with them, so promted me to do so
EBC Recommendation
Neil,
Copper based grease is brilliant stuff in the right places. The back of brake pads is one such place. Not so good on the front though.......
Also brilliant for inside bush sleeves where it acts as anti-seize compound, which is a correct application. The negative comments on here are warnings not to use it on threads that need to be torqued up, such as head bolts/studs. Some have warned against using it on the shanks of head studs because it supposedly dries out and causes the studs to jam in the heads. Not seen that myself, but it may be true.Dave
Originally posted by DJT View PostNeil,
Copper based grease is brilliant stuff in the right places. The back of brake pads is one such place. .......
Also brilliant for inside bush sleeves where it acts as anti-seize compound, which is a correct application. The negative comments on here are warnings not to use it on threads that need to be torqued up, such as head bolts/studs..
And especially use it on things like brake caliper mounting bolts, suspension mounting bolts and fixings that are going to see high temperatures.... even if it goes hard it retains some of its anti seize properties and is far better than trying to free off dry rusted or aluminium oxide seized bolts (perhaps the better option on the head studs would be the moly paste we use...)
You are using terminology that is familiar to me also. It was offshore where I learnt about it not being suitable for torqued threads (e.g. pipeline flange bolts). Molykote was used in that instance, and it would probably be good for head studs.Dave
Copper greases are fine for brake pads etc. The problem with using it on head studs is that it promotes elecrolytic corrosion. It will work for a time but people on here have found it innefective or even worse than nothing when its been on a while. Nickel based anti seize is better but the new technology ceramic based anti seize ought to be the best as the stuff is much more inert. Not tried it myself but will be using it the next time I have the heads off because the science makes sense.
Copper greases are fine for brake pads etc. The problem with using it on head studs is that it promotes elecrolytic corrosion. It will work for a time but people on here have found it ineffective or even worse than nothing when its been on a while. Nickel based anti seize is better but the new technology ceramic based anti seize ought to be the best as the stuff is much more inert. Not tried it myself but will be using it the next time I have the heads off because the science makes sense.
