After I had my running problem when engine hot, which proved to be faulty coil as per my previous thread. I had been convinced at the time that it was fuel pressure/evaporation for two reasons 1/ not much fuel even looked like no fuel in fuel filter but this seems to be normal or at least a red herring. 2/even after fitting Viton tipped float valves I would still get a slight dampness at overflow pipe but could see no petrol at overflow exit from carbs and no fuel in carb pedestal. So I had purchased a Petrol filter king which incorporates a pressure regulator from EBay, by the time it arrived I had fixed the misfire problem with new coil but decided to fit filter king as I have a non points fuel pump which I have heard may put out more pressure than standard. So before fitting filter king I checked pressure which was 4 psi, after fitting it showed 2.7ish psi but the interesting thing is that after a run and stopping I observed that the pressure had risen to 6psi. This high pressure can not builds up before the filter king pressure regulator but between it and float valves due to heat under bonnet. I wonder if there was not the pressure regulator fitted if this may have risen even more and may be the cause of the many hot starting problems for Stag owners.
FUEL FOR THOUGHT.
Cheers Greg
FUEL FOR THOUGHT.
Cheers Greg
