Hi all, I have just bought a mk 1 stag with auto box, triumph engine and have a couple of problems.
Problem 1, From cold start up and the drive is brilliant but after stopping for half an hour or so when warm/hot engine starts fine and revs ok but try to drive and it lacks power and is missing. This lasts for about a minute when it clears and from then on drives and responds perfectly. (Makes it awkward when pulling away into traffic). I thought it was a fuel supply problem but the pump is functioning fine.
Problem 2. After switching off the ignition light comes on and stays on. I have resorted to disconnecting the battery to turn it off, when the engine has cooled and battery reconnected the light is off. This does not happen every time but more often than not.
I do not know the car history so have just done an engine flush, I have refilled with new anti freeze and added water wetter. Oil and all filters, and a set of plugs. There are no knocks or rattles and the engine pulls like a train, there are no oil leaks or water leaks at all. What I have noticed is that the top hose appears to have been sucked in/contracted while cooling.
Has anybody experienced similar issues? I would love to hear the remedies if you have but all advice will be gratefully recieved. I am a diy mechanic but will have a go at anything.
