Mystery Nut Any Idea's
    Hi Guys , been working on the yellow one, fitting a replacement distributor and setting the other up as a spare for the boot with a spare lumenition ignition system as well.
    I found a nut and wonder where you think it has come from? and then I will tell you where I found it while doing the above jobs.
    Please have a look at see if you can help me identify it.
    Thanks very Guys.
    Looks like it might have been welded to something at one time?
    Is it 1/4 unf by any chance?
      Is it one of the nuts that secure the heater to bulkhead ?
        Or on the soft top frame..
          Rear Hood catches?
            It's smaller than that, must be some sort of BA thread, across flats 6.27mm, and it's 2.10mm thick.
            P1050855.jpghope this will give a scale.
              Is it off the coil?
                Originally posted by Kevin Garrod View Post
                Is it off the coil?
                Just checked that to small for the coil, but thanks
                  Right guy's, will put you out of your misery of where I found it, and also have had a suggestion of what it is, A points nut which, there has been no points fitted to the car since May 1992 and 97,841 miles now 116,000, and when I did both head gaskets etc the dizzy was left in and the top of the block cleaned and painted.
                  So this little nut has been sitting where I found it for 20,000miles and 22 years.
                  will not let me add a picture will try again later,
                    lets try again, no good sorry can't add photo,s again
                      I can only post pics from URL. it wont let me upload any from my pc. Havent been able to do that for a week or so
                        Have you tried using the basic up loader? That's the only way I can up load
                        cheers Glenn
                          cheers Glenn
                          Yes... doesn't play the game
                            mistery nut position on new thread
                            found the nut in the other thread on the little ledge on the right by the drive gear for the distributor on the jack shaft that as sat there for 20,000 miles, a trip to France and back and 22 years. how lucky it that. if the management can add this to my 1st thread that would be great.
