Just to get up to speed , I have fitted a new clutch, new HD thrust release bearing, new bearing carrier ( broke the old one), skimmed the flywheel, fitted a new spigot end bush, new slave cylinder , new master cylinder and a braided pipe between the two, also fitted a new clutch operating rod then refitted the gearbox using the locating bolt as advised. All this in an attempt to cure the juddering clutch which I have put up with for many years, took the car to work today lots of vibration at motorway speeds and a gradually failing clutch with the result that at the end of a 39 mile drive I had no clutch at all, drove it home looked underneath could see nothing wrong bled clutch again no difference, I don't know if I need sympathy or therapy, I have had this car for 30 years and I am as close to selling it as I have ever been,
HELP
HELP
