Can anyone recommend a digital temperature gauge? have just bought a Mk2 Stag. Once warmed up, the gauge sits at 3/4 and doesn't budge from that. As well as the mechanical water pump and the viscous fan it has a Davies Craig electric water pump and electric fan. I have had all these checked and are OK. The Auto Electrician says the engine temperature is fine (checked with a IR gauge). He says when the needle is vertical the temperature is 70 degrees. The voltage stabilser is fine. I would like to fit a digital temperature gauge that perhaps would be mounted under the dash. I would like it to take it's reading from elsewhere as I would k=like to stiil keep the original temperature gauge connected to the temperature sender unit. Any ideas would be gratefully received. Thanks.
Digital temperature gauge
Originally posted by V Mad View Post
