Was it worth it?
Absolutely!
The car is transformed, no violent engagement of Drive or Reverse from rest, better gearchanges, more flexibility etc. To cap it all, when TC lockup occurs it feels and sounds just like the OD kicking in on my 2.5 Pi (Stag Substitute) all those years ago. Amazingly, TC lock up comes into play at a very similar speed it did in the XJ40, that was 52 mph and mine now comes in at an indicated 49 mph in the Stag. To see the lower RPM at or above 50 mph makes it so worth all that hard work!
One or two questions I could not find a definitive answers for, to help others researching;
Yes, you can remove and then fit an auto 'box to the TV8 by simply removing the front exhaust pipes and tilting the engine back. The crankshaft centre bolt actually moves away from the radiator, not closer to it. You don't even need to jack it. The only things you have to keep an eye on are the lower blades of the plastic fan.
Yes, you can contrive a mechanical speedo drive by fitting a gear inside the rear housing, but you also need a 90 degree elbow drive and a different cable end to suit it. I haven't checked accuracy with the Sat Nav yet, but it'll happen.
I'll carry on tweaking the kickdown and gear selector adjustment until I'm happy, and then what next?
Perhaps the Brake Servo. I thought Stag servos were just badly chosen at only 3x pedal effort, but I drove another Stag the other day (I've only ever driven mine) and it turns out mine feels bad 'cos it just doesn't work! How was I to know?
Absolutely!
