Hi all,
Was messing with tightening inlet manifold bolts to stop coolant leak the other day. That seems to have worked, but i had to remove the coil and ballast to gain access to bolts.
Put coil back on, and also fitted a Malpassi fuel line regulator for a flooding carb and started car.
During cranking, my son noticed a spark flash around the coil and ballast area. Stopped car pronto.
Checked all around and the correct compliment of wires was going to coil and ballast, but the tape job included a purple/white wire with the orange/white and grey/white. The purple/white was exposed and obviously live!
Is this the old temp warning light wire that was cut in early times? I can't think it would be any other wire; other purple/white wires run inside the car. That was bloody dangerous wih all petrol fumes around, I must cap it properly. Just thought I'd pass on the warning.
Tanya
Tanya
