Another question!
This is all on a Mk2 Stag I have bought a few weeks ago. As noted in my other recent topics, I have drained all the coolant out of rad and removed the engine plugs and drained the engine. All nice and clear, the previous owner must have done this regularly. I removed the stat and refitted housing then refilled. Trouble was I could only get about 6 litres and the rad flush in. Warmed the car up then drained and flushed again. Took the rad off and flushed that. Fitted rad back, fitted new thermostat (with jiggle pin and foot). Put in 3.5 litres ethylene glycol antifreeze but could only get in about 1.5 litres of water in. Car near side was jacked up. I had removed the heater pipes and swapped over to fit into the heater the correct way round as ROM. Though I believe some people connect the pipes the other way round to avoid air locks. Is this OK? Anyway, How much coolant should I be able to get in? I though it should be 10.5 litres.
