stag near disaster beware
    hi everyone recently got my stag on the road after a 4 year rebuild,its a 76 in topaz.as I thought the old washer bottle looked tired I bought a new replacement from a well known supplier,fitted it and all appeared to be well.i pulled into a service station for some fuel and noticed a horrible burning smell,i opened the bonnet to see that the washer bottle had fallen off onto the exhaust and was burning away/melting.i dragged it out and stamped it out, I thought idiot I obviousiy had not fitted it properly so I ordered a new one.when it arrived I fitted it and to my surprise when filled with water it fell off and was a terrible fit,i returned it for an exchange and the new replacement is identical,a terrible fit.i have had to secure it with a stainless cv boot strap,so beware if you buy one of these check when it is full that it is secure.i will be speaking to supplier tomorrow
    I was cleaning my expansion bottle today and like you I thought that I would replace with new however after reading this I am having second thoughts.
    Does anyone know how to clean the old bottle?
      I bought a similar item from a not so well known supplier. It also fell off when the bottle got warm. It is very close to the exhaust system on my car. I subsequently fabricated a steel support bracket which also acts as a heat shield.
        I think our method is a Siemens but it could also be a Bosch........ (not putting it into words in case SWMBO finds out how I got it so clean!)
          Btdt twice. Ended up reshaping the bracket to suit the new bottle and it's been ok since.
            Sounds like a plan
              ive also had that ,as daddy said reshape the bwacket and all fine
                Mine too. Yet another case of .. "its close enough "
                  Exactly the same happened to me so am using the old bottle now
                    Hi,I used sterilizing fluid+dishwasher,then I found out it leaked from the bit where it fits onto the bracket, so cut down a milk carton(plastic bottle)and fitted that inside the original bottle whilst a new one came,as It was MOT time and so needed some water in it.New bottle came,, from a well known supplier,, and seems to be secure enough.Mind you I put some sheathing on the metal slider ,where it clamps the bottle.
                    Ken.
                      If anybody keeps tropical fish, use the poly bag (or similar) that they give you when you buy fish and pop it inside the original bottle-leak free.
                        Indeed but why cant they just make the replacement bottles fit the bracket! it's infuriating!
                          Hi, Use a saloon one, much more durable.
                          Cheers Ian A
