Probably another daft question!
I always top up the radiator (Mk2 Stag) right up to the brim. Now, I know that there is a slight leak of coolant into the vee, but whenever I take the rad plug out, the water level is approximately half way up the top hose. if there wasn't a coolant leak should the water level be higher?
What I don't understand is that the overflow pipe across the top of the rad to the expansion bottle passes below the top hose. So how can the coolant suck back from the expansion bottle to a higher level than the overflow pipe?
I could understand this might work perhaps if you have a perfect vacuum in the system with not the slightest air ingress and the pressure that is built up in the expansion tank due to the expansion of the hot coolant is retained long enough to help push the coolant back into the rad and into the space above the overflow pipe.
Surely in a 37 year old car it will be virtually impossible to maintain a 100% sealed system?
Is my thinking correct or am I missing something here?
