Looking for some opinions on a minor issue with SWMBO's TR7 which has basically the left hand half of a Stag lump.
I just noticed today, a very slight puff of blue smoke that only happens after its been driven fairly hard in a gear and then you lift off. It puffs just as you lift off but doesn't continue if you let it stay on the overrun. In normal driving it never happens or at least if it does it isn't noticeable.
The only investigation I have done so far is to check for crank case pressuriation and it does chuff fairly strongly from the filler cap on idle but when I pull the breather from the cam cover and put the cap back you can feel little puffs coming from it but nothing like as strong as through the filler hole.
I was thinking valve guides and or stems until I felt the crankcase pressure, now I am wondering if the flame trap in the cam cover being blocked might be a possible cause?
