I'm fitting a Kenlowe fan in front of my rad and will have a manual switch under the dashboard which will switch the fan via a relay. I want to take the power to the switch from a location within the cabin that will go on/off with the ignition. Where is the easiest place to connect from causing the minimum taking apart of dashboard etc?
Thanks
Thanks
