image.jpgThanks Steve (Stagmuffin) for recommending I replace my core plugs.
My core plugs looked immaculate and thanks to Steve's suggestion, I decided to replace them.
I found them harder to removed than I expected. I tried the technique with a self tapper screw and stilsons but found the core just dished outwards and the screw suddenly let loose. I then tried tapping them out with a hammer and chisel/screwdriver, my first couple were really hard work and the inside surface of the first couple out we're immaculate, and I did think of leaving the rest . Luckily I persisted, as a couple of the next ones were so rusted through on the inside, that they were paper thin.
I found the core plugs in the block were much easier to remove than the ones in the heads.
Despite being careful, I managed to knock 2 into the head waterways, but they were easily removed.
I have only found and removed 11 so I think I have a couple more to find? Also there is one on the inlet manifold to do.
What is the best way to push in the new ones?
Should they go in flush or should they be submerged slightly?
Dave.
Dave.
