As per the title.
I have been having "issues" with the Stag refusing to start recently (This week) Starts first crank with the booster charger but never after its stood over night or outside at work.
I thought the drive belt was slipping and so fitted a new one at work.
Drove the car home, around 7 miles, turned it off and restarted it no bother. As soon as I got in the house the misses wanted to go out to local shop .... went outside and turned the ignition switch the engine cranked for a very short time and then "BANG"
white smoke pouring out from under the bonnet. Popped the bonnet to find the top of the "maintenance free" six month old battery in pieces and the remains of the acid dripping down the underside of the bonnet.
The panel above the battery is deformed upward and torn away from the side of the radiator support panel. (Not major damage but an amazing show of power!)
The symptoms before the explosion. The battery voltmeter always read over 13 volts when the engine was running. If the lights were turned on or the fan or even the windscreen wipers, the volt meter dropped to just below 13 volts and stayed there until the lights or whatever were turned off again. The volt meter then returned to the same level at just over 13 volts.
History.
The battery is 6 months old brand new at time of order.
The alternator was changed 3 months ago due to a continual "overcharge" state of the battery (in the red on the voltmeter) and eventual alternator failure. New alternator fitted and over charging issue no longer a problem
The car has been used every day since the beginning of August and has never, until now, missed a beat other than a slight hot under the collar incident at National Day during the world record attempt...
My own thoughts are that the damage was done when the alternator was overcharging the battery. I fixed the fault by replacing the alternator but I never checked the water level of the "maintenance free" battery afterwards.
I now think the battery fluid level has become too low due to overcharging by the old alternator. The new alternator has been charging fine but the battery has stopped holding its charge due to the low fluid level.
The booster starter has then continuously over charged the nearly dry battery this week until the gas pressure got higher than the battery casing top could hold...BANG
New battery required, copious amounts of water to flush out the acid deposits in the engine bay and a lesson learned.....
Don't believe "maintenance free" entirely. If there is ever any "overcharging" check the fluid level even in a maintenance free battery and as soon as there are any starting issues with your car always check the obvious things, loose battery cables, battery fluid level, drive belts before "bunging on the booster!"
Now off the road till the new battery arrives!
white smoke pouring out from under the bonnet. Popped the bonnet to find the top of the "maintenance free" six month old battery in pieces and the remains of the acid dripping down the underside of the bonnet. The panel above the battery is deformed upward and torn away from the side of the radiator support panel. (Not major damage but an amazing show of power!)
History.
