I have now run my Stag (RV8 SD1 10A + Holley 4160 4 barrel carb) for two years. Never given any problems but feel it should be bit smoother and quicker (odd cough and hrumph when hot). Till last week there were two hoses from the rockers up to the bottom of the pancake filter but someone pointed out that on the SD1 there were flame traps. So I fitted these (see pic) and a welcome and unforeseen benefit was that the pool of oil in the valley en route to the garage floor disappeared.
Being of a curious nature I delved into this breather pipe problem and found all manner of suggestions on the web. The original SD1 had one pipe via a flame trap to a twin branched pipe to vac pipe of each SU. The other rocker cover outlet just had an open pipe with a flame trap. Others on various forums (using the SD1 in a variety of cars) had blocked off the outlets completely.
However on the TR7 forum someone who seemed to know what they're doing said that the RV8 was designed to have Positive Crankcase Ventilation and the breather pipes should be routed into the vac port with a PCV above the flame trap on one rocker cover. I hunted through Mr Haynes and Mr Rimmer and there is no mention of a PCV on the standard SD1 engine, only on the EFi.
That seemed to make sense to me - so I removed one pipe but left a flame trap and ran the other up to the large vac port of the Holley - I don't have a PCV (yet). And, woe and trice woe - the bugger would barely start . . .
So for the moment it's back to how it was - breathers up to air filter, Holley vac port blocked.
Gentlemen: your expert advice please.
