A gentle trip out yesterday showed me that Buttercup was staging yet another little protest at being roused from her gentle slumbers.
Turns out the "hot-cold" heater control is no longer connected to the water valve. Re-hooking that cable is a job for another day!
However the water valve can easily be manually operated. When I did so, the heater output was less than I recalled from last year.
I felt that an airlock might be the problem as I had drained and refilled the system recently.
I also decided to swap the hoses over to ensure that the feed is into the "bottom" of the matrix, to help bleed any entrapped air out.
So........the point of this post is to help anyone else ID the correct pipe to put on the lower connection. It is the long one that comes over from the water transfer housing on the rh head as you look onto the front of the engine.
I connected this onto the lower position, (trimming the pipe so that it doesn't rub on the back of the lh head) and refilled and voila! Toasty tootsies once again.
