FUEL LAMP
    FUEL LAMP
    Hi guys!
    My fuel light coming on intermittently (flashes random) even with half tank!!! do I assume sender unit ?-or is this relevant to voltage reg problems? (74mk2) also is sender unit same for MK 1 and 2- or different? is replacement straight forward? as never swapped same!
    as ever all help appreciated!
    CHEERS!
    PHIL:dude:
    They all do that sir.
    The fuel gauge needle is well and truly damped, whereas the the light operates from the sender unit float which follows the fuelsloshing about in the tank.
    Mark.
      Thanks MARK! YOU HAVE PUT ME MIND AT REST!!!!..... was nearly lashing out on a new sender!
      :dude:CHEERS!
      PHIL
        Mine starts flickering when the guage gets to a little under half a tank. The nearer to empty you get, the more often it flickers! Perfectly normal.
          Hi John !
          Thanks for info! nice to know I have a normal condition!!!
          :dude:Cheers!
          PHIL
