I posted a while ago about somebody that I know that can spray ali and rebuilt cylinder heads back to their original thickness. I have had some feedback on this and got some quotes.
To weld any corroded parts and skim back to flat, spray the ali to build up the thickness, reface the heads back to +/- 1mm of original spec. Would cost £520 per pair.
Renew valve guides and re-cut the valve seat when the above work is being carried out- Would cost £30each.
To completely rebuild the heads to original thickness, with new guides, valves, buckets and re-shim, excluding cam and assuming the cam is true and not out of line or bearings scored. would cost £1400 per pair.
All plus p+p. or collected.
I am not a trader, but I am prepared to be the go between if it helps anybody out, but any sign of negative comments etc then my offer stops. If anybody sends their heads to me, make sure that they are packed well as the same packaging will probably be used for their return.
So you could get fully reconditioned heads that should last many years for £700 each.
I must express at this stage that I do not want to take the benefits and hard work away that SOCTFL have done in re-manufacturing the new heads and all credit to them for their efforts. But I do know that the cost will be above many members budget.
One other request is that if anybody has scrap heads lying about or old valves (which would be used for masking) that they would like to donate, then it might be possible to recondition them for exchange purposes.
I would also recommend that you clean and flush through the heads before being sent. If it is just the re-facing that is required then all that is needed is the bare heads with valves still in tact.
PM's welcome.
Hope it helps
Bob
PM's welcome.
Hope it helps
Bob
