I fitted a new electric aerial today, unfortunately it didn't come with a switch and it is designed to raise when it receives a signal from the radio. I have a 60's radio installed however and this doesn't have an aerial feed, I therefore need to use a switch. The aerial has 3 wires, one Earth, one permanent 12v & one for an aerial feed from the radio. I jury rigged a 12v supply and when I connected this to both the 12v supply wire and the aerial feed wire the aerial went up, if I remove the aerial feed wire it doesn't retract however. I'm looking for advice as to what kind of switch I should get to be able to raise and lower this aerial, any thoughts?
