Hi all
I thought i'd start a new thread related to my recent acquisition, A 1977 MK2 Stag manual O/D
It is a nice old beast, runs well, no major rust, some just started and looked like someone started to bog over it....
I did run around with a magnet on 3 separate visits before I bought it, so I did have an idea if some metal had been patched.
On the last visit I did see the owner driving around so was able to see/hear the car. ie no smoke or funny noises. PS he didn't know.
I was able to give it a good check over, on car ramps also.
My thoughts were someone has put a lot a work into restoring it, a fair while ago.
Since I've got the car I've been looking for nasty business ie the rebuild butchers.
I have to admit, I think I might have got it in time.
As for the rust bogged, one place A pillar, sussed it with the magnet.
Next day after getting it home, screwdriver, hammer to chip out the bog, and steel wool behind it
Any other, seems surface rust and has been ground back.
Good things I've found, are suspension rubber look to be Polyurethane ones, Petrol Tank still has "Rimmer" sticker on it, fuel pump looks new.
under the Dash, the wiring is labeled(unfortunately some of the ink has faded away.
Untidy?? I just pulled it out looking for white/pink for installing car radio.
The cars registered still, but have been checking it over.
Only oil leak seemed to be the rear of the rocker cover, tightened up rocker cover, no leak.
Hmmm cars sits in one place in the garage, and no oil on the floor..........
I even got an oil drip tray ready.
I won't mention the soft top.
  but as you describe your car as a recent acquisition you may not know that the fusebox and all the terminals are easily accessible once the passenger parcel shelf is removed and this is just fixed by three or four screws.
 but as you describe your car as a recent acquisition you may not know that the fusebox and all the terminals are easily accessible once the passenger parcel shelf is removed and this is just fixed by three or four screws. .
