Hi All
The water pump successfully came out with the use of a slide hammer Stagdad's external pump kit is sitting on the dining room table waiting to be installed
 Stagdad's external pump kit is sitting on the dining room table waiting to be installed . The issue now is how best to remove the remains of the setscrew that snapped whilst removing the old pump cover. Its remains are sticking out of the block by about 10mm. Its the one in the higher position. Is it a blind tapped hole or does it go all the way through into the water way beneath?
Any suggestions?
Bruce
. The issue now is how best to remove the remains of the setscrew that snapped whilst removing the old pump cover. Its remains are sticking out of the block by about 10mm. Its the one in the higher position. Is it a blind tapped hole or does it go all the way through into the water way beneath?Any suggestions?
Bruce
