I've taken the opportunity to overhaul the oil pump and fix a leak whilst changing the exhaust. Now having dismantled and cleaned the oil pump to examine it I have found that the wear is well within the ROM limits
However, the end face of the rotor has some score marks from cruddy oil (this is a common issue I have found as I overhaul engine parts as the engine has stood for long periods in its life).
So, my question to you all is what are the thoughts on the acceptable amouts of scratching? Also, can the ends be dressed to take away the scores?
Thanks in advance.
Thanks in advance.
