How have you guys fitted your foglights. Have you made a bracket or is there one available ?
fog lights
When I first bought my car it had a hole in the middle of the front bumper into which I slotted a fog light (see pic).
I used to have a couple of small red rear fog lights at the rear fitted on brackets, but they got damaged so removed them as don't get any fog in Tenerife,
but I have left the front one on and have it wired to the 2 spotlights below the bumper so all 3 work off one switch.
Here is where my rear fog lamp is
P6080164.jpgDanny 1972 STAG Mk1 TV8 Auto, 1967 SPITFIRE http://www.grampianstags.net
images[4].jpgFor me if you have a decent set of headlights why is it necessary to spoil the lines by hanging more lights on. Unless you used to ride one of these.
20130619_132030.jpgOriginally posted by malc4d View PostHmmmmm, givus a clue.......
I've done the same - replace one reversing light bulb with a 21W red bulb and a small change to the wiring. An invisible (almost) solution. Can get bulb from eBay like this one.
Thanks
