Trim ??
    Trim ??
    Morn. fellow Stagers..
    Anyone know where these bits go...
    Malc,
    I think they may be the water curtain pieces that fit between the interior door handle and the main water curtain in each door. They would be 631388, if so. The larger holes are for the rods to the door latch, the smaller holes for the screws/attachment.
    Michael
      Thanks...but no, not them. Did you get my PM ?
      This is trim vinyl. The smaller holes make it look like it somehow goes on top of the B post under the heated window sockets........
      Hmmmmight have found a picture of it in the parts book 06-43 top right. But doesn't show where it goes..........
        Does the parts book give a Triumph number you could use to search the Rimmers website?
        This website has some cross-references but doesn't seem to go as far as 06-43....http://www.stagbytriumph.co.uk
          GRID005455.gif here
            The carpet section that covers the heel panel (vertical panel below front if rear seat) has a square of vinyl sewn in the top corner of each end. They cover the access hole for the top of the rear subframe mount bolt. Could these pieces be what you have?
              Nope, they come attached to the carpet and no holes.......Still thinking B post but cant see why, how.......
                Bearing in mind that neither Dave nor I recognise it ( and I thought I knew almost everything there was to know about Stag trim ), but that it is shown in the parts manual, I wonder whether it is something that was federal or LHD specific - heaven's only knows why though
                Ps What size are they ?
                  I think they are used to cover the rear wheel arch where the rear static belt attaches to the arch, hence the hole. They disguise the colour of the arch through the slot in the cubbie panel.
                  regards,
                  Raoul
                    AAAAAAAAAAAAAHHHHHHHHHHHHHHHaaaaaaaaaaaa !!!!!!!!!...........Give that man a peanut ! I will try looking there today.
                    Spot on Julian. They seem to be. About 5" square.
                    Any Pictures ??
                      I'll take some pictures tomorrow, that will be two peanuts! The size you quoted seems about correct
                      cheers,
                      Raoul
                        They fit........Not sure what they do, or how they fit properly. seem to go under the belts.
                          Malc,
                          Ah, I knew I should ask about material and size, not just color and appearance. Sounds like you've got the answer.
                          Yes, I got your PM, and replied to it.
                          Michael
                            Yes they fit under the belt attachment point and they are glued down with contact adhesive.
                            Ill post a picture when I come home from work, tonight.
                            Raoul
                              Thanks....
