Cutting Out
    Cutting Out
    Ok Just a little tester for all you experts out there !!!
    As some of you are aware i've got a electric pump, and the switched feed is through the brake light switch.
    Now i've just moved the sensor that regulates the pump speed to the back of the O/S side cyl head (transfer housing) and in the process managed to break the oil pressure pipe leading to the gauge.......... ordered a new pipe and fitted it, butwhile trying to remove the old pipe from all the wires a crap behind the dashboard, managed to pull the wires off the brake light switch................no problem refitted and went for test drive called into petrol station put 20lts in and set of.......... about 4mls later in the pouring rainas I braked going down a hill I noticed rev counter was not working....... funny then realised engine had cut out, so coasted to a layby put gearlever in park (automatic) turned key........ started straight away, foot on brake pulled lever into reverse engine stopped.......Hmmm back into park turned key started straight away foot on brake pulled back to reverse stopped again, then I realised every time I put my foot on the brake the engine cut out............ so I removed wiring from brake light switch ran a cable straight from the battery to the pump controller and drove home no problem.
    I have now sorted the problem but wondered if any of you can guess what the problem was?
    give me a clue - is the new oil pipe copper or plastic ?
      I'm guessing that you mixed some wires up behind the dash and when you press the brake pedal the ignition circuit is shorted out?
        Copper
          I'm guessing that you mixed some wires up behind the dash NO
          But the ignition circuit was cutting out
            Hi Roger,
            I assume you have Lumenition. Where is this fed from? Am I warm?
              Im guessing its the big nut behind the steering wheel that did something !
                RogerP wrote:
                copper
                Ok - here goes - the copper pipe from the oil gauge was touching the "dead" terminal on the brake switch, thus when the pedal was pressed it became live and shorted out the circuit.
                  DJT wrote:
                  Hi Roger,
                  Hi Dave
                  Yes I have Luminition......... cant remember where I picked up the feed.
                    Andy
                    Just occasionally your right.............but this your right of the mark
                      stagowner wrote:
                      RogerP wrote:
                      copper
                      Good theory - but sorry wrong.
                      To be fair the work I've just carried out has nothing to do with the problem...........bit of a Red Herring.
                      If you re-read and take out all of the work what are you left with? This could happen to anybody.................In fact it happened to me in France earlier in the year, when it was doing the same thing.
                      Now thats a big clue.
                        Hi Roger
                        If the fuse (3-4) blows, then having both the Stop and reversing lamps on could ground out the tacho therefore pulling the voltage down at the distributor, a bit obtuse but a possibility. The extra path due to the water pump would not help either.
                        regards
                        Barry
                        sigpic Mk2 Sapphire 1976 mod, & Mk2 Sapphire 1974 4sp auto. (plus red/white wreck)
                          Barry Brown wrote:
                          Hi Roger
                          regards
                          Barry
                          Hi Barry
                          Your going to burn your fingers very soon...................but not a blown fuse...but so close, have another go!!!!!!!!
                            the big nut behind the wheel blew a fuse ?
                              Roger,
                              If one of your brake light bulbs was shorted to earth, then pressing the brake pedal would ground the 12v feed to your pump, and it would presumably stop. Bulbs usually fail open circuit, but short circuit is not unheard of. Crud in the bulb holder can short things too.
                              If it happened to you in France, then it was probably the12th caseof Burgundy you tried to squeeze in the boot, broke the protective cover over the light cluster and smashed to bulb holder. Don't be so greedy!
                              All the best
                              Ray
