A couple of months ago, I'd noticed that my fuel pump (SU - possibly original one) continued ticking with the ignition on, rather than the customary tick...tick.. (for a few seconds) then stop. First thoughts were sticking float valves but no fuel was getting dumped out of the overflow pipes. However, despite this, the car continued to run perfectly well  , so I just carried on using it.
Anyway, for one reason or another, I didn't use the car for a few weeks, but when I tried to start it, it had a flat battery. I started it with a booster pack but it died after a few seconds and this happened on several further attempts at starting. Investigating further, I could still hear the pump clicking continuously and guessed that maybe something like the diaphragm was damaged and it wasn't pushing through enough fuel to keep it running. Still with me so far?
As luck would have it, I have a spare fuel pump that I got from Peter at LD (one of his electric ones). I fitted that but, much to my surprise, that continued clicking and I had the same start...run...die problem as before. Hmmm..two pumps, same symptoms
That then led me to think that it could be a leak somewhere on the inlet side between the tank and the pump so it was sucking in air. However, the plastic pipe looked good as did the banjo. I then tried disconnecting the pipe from the tank and putting it into a petrol can, to try to rule out any problem with the tank. Maybe it's not the pump or maybe they're not priming themselves properly I thought. Anyway, to cut a long story short, I did everything I could think of, including fitting new fibre washers, but to no avail.
Whilst my original pump was still fitted, I ran a separate 12v feed to it, just in case, but it made no difference. Finally, in desperation, I swapped over and fitted the new LD pump with the separate 12v feed and, guess what ? it kept ticking, but, lo and behold, the car started and continued running ok
So, my theory is that my original pump has a problem (quite what, is yet to be determined) but also my battery wasn't putting out enough to make the new pump operate correctly - so in fact it seems that I had dodgy old pump and a good pump with a dodgy battery - both giving the same symptoms
I’ve been running with the new electric LD pump for a few weeks now and all seems to run ok, however, the pump continues to click ALL the time – no click..click…stop
So, my question is, has anyone else experienced this ?
, so I just carried on using it.Anyway, for one reason or another, I didn't use the car for a few weeks, but when I tried to start it, it had a flat battery. I started it with a booster pack but it died after a few seconds and this happened on several further attempts at starting. Investigating further, I could still hear the pump clicking continuously and guessed that maybe something like the diaphragm was damaged and it wasn't pushing through enough fuel to keep it running. Still with me so far?
						 she seems to be running better than ever !
