steering column bolt removal
    Hi everyone
    After a summer of getting to know my car. Last week we had a short on the light switch wirring and I need to replace the wiring section under the steering column. Today I spent most of the day trying to remove the steering adjuster bolt, but to no avail. Can anyone advise how to remove it as the manual says it just pulls out. On my MkI the bolt won't come out.
    Mark
    Moved from technical section
      Hi mark
      If its the same as a mk 2, there is a small roll pin that holds it in place. Look for a very small hole in the housing the bolt goes through. I found it easier to unbolt the housing from the dash, 3 bolts, but one of them can be a bit difficult to get to.
      Hope this helps
        Whilst the diagram isn't especially good, I've tried to show roughly where the two holes are that contain the roll pin that Dave describes.You just need something like a nail (preferably blunted to prevent it opening up the rollpin) or small screwdriver and a hammer to push out the rollpin.
        Good luck. Cheers
          Thanks Julian, Iknew you'd come up with the answer.
            Two threads on same subject, thanks Dave, knew someone must know the answer
              Now....Is that roll pin really needed ? I never put mine back years ago...
                I used a thick split pin instead as I opened the roll pin by using a sharp nail to drift it out.
                Ross. Perth WA.
                1976 TV8 BW65 Tahiti Blue
                  I would say that with a good Nyloc nut fitted there is no need for the pin, and its a complete nuisance. But a split pin would be better if you want 'belt and braces'.
                    I've run mine without a pin for years although there may be, potentially, a very dangerous problem - perhaps someone could check it out.
                    I was driving once and, for heavens only know why, I decided I wanted to adjust the wheel whilst moving (Yes, I know, you shouldn't ) so I slackened the adjusting handle but, as I did so, I approached a slight bend.
                    Turning the steering wheel, with the adjuster slightly slackened, led to the column nacelle turning, but NOT THE WHEELS . Was this because I'd left that roll pin out or not ? - I think not, however, since then, I've never tried adjusting the steering wheel position whilst on the move
                    If someone wants to check if this happens on a car still with the roll pin fitted (you don't need to be moving !) then, if so, it would seem that leaving out the roll pin makes no difference.
                      Great thread ,my adjustment is nill ,neither in /out or up or down (I'm very new stag owner ) can I just loosen this bolt? all thoughts welcome ,please,so I tick off one more job on a fairly long list
                        There is a lever to the left of the column - if you swing this around 180° it should slacken the steering column and then you should be able to both raise/lower the wheel and also move it in/out.
                        The action is often stiff if it's not been used for a long time - in fact some owners don't realise that the Stag offers this facility
                        Mulian
                          thanks i've moved the lever ,but no joy
                            Ok, that lever operates on a bolt that goes through the bracket and, on the other end (to the right of the column) there's a small (3/8" AF ?) nyloc nut.
                            If you slacken that, it should reduce further the clamping force on the cvolumn and free off the column adjustment, all being well.
                            Let us know how you get on.
                              Thanks Julian .will do
                              cheers Alex
