bonnet seal
    bonnet seal
    I have just got car back from body shop just had a respray I could not find bonnet seal sent off for one found it does not have any clips has anyboby fitted one of these told to stick with contact addisive does the long side of seal go to back edge of bonnet
    Unfortunately original bonnet seals are no longer available, the only available seals need to be glued on, Can't help you with orientation though, sure someone will know.
    Kind regards
      I used double sided tape on mine, worked no problem. can't remember which way though. I'll have a look tomorrow if you don't get an answer first.
        Since the Stag gets hot under the bonnet and the vent ideas may not be optically pleasing.
        Is it worthwhile using the rubber sealing strip?
        Allan
          The open side of the 'V' should be on the windscreen side ie the 'V' points forwards.
          When I fitted mine I managed to find some very small plastic barbed clips (from Bresco or Woolies IIRC) and drilled small holes in the rubber for them - a little bit like the original except that the head of the clips isn't buried in the rubber. However the head is rrasonably well hidden by the other side of the rubber 'V'. It's not perfect but I'm quite happy with it.
          Don't use Evo stic I'm a big fan usually but it has changed my green paint to blue where I've used it !!
          As for leaving it off, over time you get a surprising amount of oil laden fumes coming out and it will make the screen oily.
            Good point Julian
            The rubber that sits between the bonnet and the air intake for the car interior.
              Use polyurathene mastic put a thin line in the V and push on it will never move
              Once you have built a ship everything else in life is easy
                Julian, could you or someone take a photo of this Rubber in Situ ? My Stag did not have this. Surprise Surprise !!
                Also, where do you buy this from ? Thank You
                Finally got Married on 27th June 2015.
                  Mine didn't come with one, and I won't be fitting it either. A reasonable amount of hot air comes out of the resulting gap when the fan is running and you are stuck in traffic, which has to be beneficial. It's easy to check by leaving the engine running and putting a hand over the gap - it works!
                  Given the lack of upper underbonnet (I hope that makes sense!) ventilation (no gills or bonnet louves on the Stag) it's worth taking every chance available to move some of that heat out, just IMHO. I've gone a bit further. I might describe that someday.
                    Photos as requested:
                    Well worth fitting for reasons mentioned as well as supporting the trailing edge of the bonnet. It will make NO DIFFERENCE to under bonnet temperatures. If it did then I'm sure Triumph would have deleted it, but they kept it in production until the very last.
                    Available from the usual suppliers.
                      [ATTACH=CONFIG]30994[/ATTACH][ATTACH=CONFIG]30995[/ATTACH]
                      Thanks Dave ! WoW - that is one Clean Bonnet ! It's so shiny !
                        My bonnet seal was removed in the late '80s on just the theory that it let a bit more heat out. Actually it just rusted areas away where the wheel arch meets the bulk head presumably from water running down and getting behind the bulkhead sound deadening pad. Might be ok on a summer only, otherwise garaged car, but mine is getting a new seal regardless.
                          thanks for comments have though about double sided tape give that a try first did not like the idea of evo stick now I know which way it goes thanks
                            Its called a seal umm I wonder what it does
                            Edd
                              Edd
                              Swims in water and chases fish?
