fitting socket.JPGMount 2.jpgsocket in position.JPGTomTom in place.JPGback to normal.JPG
I have to admit that the satnav is something of a must have these days but I hate having a current day products added to my '73 Stag and I have managed to make a mount for the TomTom which can be totally removed in five seconds and the car returned to it's classic looks.
I have made a bracket which fits onto the back of the centre air vents and have mounted a cigarette lighter socket onto this which is then powered by an ignition controlled 12V supply.
I have then 'modified' an plug which used to have a universal phone mount so that it would accept a TomTom mount.
The 'modified plug' provides power (12V) to a 12V cigarette socket into which is plugged a 5V USB cigarette plug. This then powers the satnav mount by way of a short miniUSB/USB lead.
To fit the satnav, simply rotate the two air vents through 90 degrees so that the rears of each vent face each other,
Then insert the 'modified plug' which is then live with a 5V supply and the place the satnav onto the mount (on a TomTom 5000, the mount is magnetic).
To get back to 1973, simply pull out the 'modified plug', swing the two vents back to their normal position and store the satnav and mount in the locked glovebox.
Looks good when the satnav is in place and provides a powered supply without wires all over the place and is easy to get back to original looks.
I need to finish off the installation by painting the bracket at the rear of the vents black so that it is not visible.
It's a it tricky getting everything lined up and you need a thin plug to modify ( the gap between the two vents is a bit tight) but I am well pleased.
As this is my first post, I hope the photos attach properly.
Stag is now mothballed until the new year. Had a great drive yesterday with the roof down - sunshine and 3 degrees.
Until I got hit twice by the salt spreaders.
