poking around my engine bay there are a lot of brittle wires especially back of engine and I want to replace them whilst I have good access! is there a part loom that can be bought just for the engine? I haven't found one if there is
failing that does anyone know a supplier of the correct coloured cables Triumph used for coil/warning light switches etc..?
thanks Mark.
failing that does anyone know a supplier of the correct coloured cables Triumph used for coil/warning light switches etc..?thanks Mark.
I want to change all coil wiring and both oil and water temp switch wiring as a minimum, they are cracked all over the place from heat!
