Afternoon learned ones. My recently acquired mark 1 auto (BW 35) had a small transmission leak when I bought it in June but this has now reached epic levels (i.e. about a pint over 8 weeks when standing. Looking at the Rimmers catalogue I can see that the dipstick tube is mounted almost in the sump using a banjo bolt? Is it probable that this might be the cause? The PO said that as far as he could determine it only leaked while standing and the increased loss would seem to be due to a fastening working loose, while I assume that in driving the ATF is forced up from the sump thus leading to reduced leakage? (Please don't laugh at my ignorance, I'm happy to admit that I regard all transmissions as sorcery!)
If this is the cause is it safe to give the fixing a good tweak or am I likely to strip threads? If I do have to dismantle the dipstick tube, presumably I should drain first? If so does it make sense to whip the sump off the Autobox and renew its gasket. How hard can it be? (With apologies to Top Gear,)
Any thoughts would be welcome.
David
David
