retrosound speaker
    retrosound speaker
    Hi, anybody know of a stockist for the dual coil 5x7 retrosound r 57n speaker that fits in the front speaker grill in the uk please? they only seem to be available from the usa, any help appreciated, thanks in advance Derek
    If you Google retrosound uk you'll find 'Classic car stereo' - that's who I got mine from - sorry, can't post a link.
      I got mine from Wards, was about two years ago though, so dont know if they still stock them?
      regards
      Tony
        Hi
        I bought mine in May 2012 from Classic Car Stereo
        The one I bought was a Retrosound 7” x 5” Dual Voice Coil speaker, Code: CS008 and with postage it was £57.85
        Very pleased with it and I just removed the glovebox and it can be squeezed in between the speaker opening and the heater box.
        I cut off two of the grill lugs so that they didn't foul the new speaker and made really sure that the electical connections were well insulated so that they couldn't short on the metal of the heaterbox.
        Hope that this helps
        I can try to photograph the installation if this will help
        Best regards
        Paul
        1973 Mk 1.5, TV8 MOD, Sapphire blue, Kenlowe, header tank, elctronic distributor
          Please please photos would be great. I have one and it will not fit ...
          ( I might have it for sale soon...).
            Now I'm on a proper computer I can post a couple of pics.
            Last edited by jleyton; 9 January 2015, 09:05. Reason: pics didn't display properly
              [ATTACH=CONFIG]31827[/ATTACH]
              [ATTACH=CONFIG]31828[/ATTACH]
              [ATTACH=CONFIG]31829[/ATTACH]=[
              No you can't. Better get back to your 'tablets'
                Mine will not fit between the central airduct and the dash. Grrrrr..
                  Don't know what you mean Dave
                  Malcolm. IIRC I had to fettle my central air vent a bit
                    Oh........how big a hammer. Julian ??
                    IIRC ?
                    Doh !! got it ....if I remember correctly
                      If I remember correctly, I cut a semi circular section out of the top of the central vent body.
                          Thanks all for the replies and info, Derek
                            There is no need to cut your air vents. If you off set the speaker ever so slightly towards the back it will miss the vent . On Julian it's very slightly forward . Mine fitted a treat but I had to use a vibrating cutter to enlarge the rear opening right up to the edge .
                              Hi again
                              I've taken a few photos of the installation of my Retrosound 7” x 5” Dual Voice Coil speaker, Code: CS008.
                              Remove the glovebox door
                              Remove the plastic glovebox
                              Attach speaker wires to speaker
                              Cover speaker's electric connections with pvc tape to prevent shorting on metal of heater box (you can see this in the photos - red tape
                              Slide speaker carefully into position - this can be assisted by using one hand through the speaker grill aperture to 'wriggle' the speaker
                              The speaker is a tight fit between the upper surface of the heater and the lower surface of the dashboard and requires no other fixing (in my opinion/car)
                              Ensure that the four 'prongs' on the speaker grill are not going to puncture the speaker material - I cut off two of the prongs to ensure that this was not going to be a problem
                              Reassemble the glovebox and enjoy
                              I have been using this set up together with an additional two speakers in the rear cubby holes for the last couple of years with no problem (vibration etc)
                              Paul
