How long is the power steering belt?
    Hi After fitting the Tony Hart kit i'm finding the alternator is very close to the inner wing, ideally a belt shorter by about 1 inch (25mm) would be better
    Anyone know of one?
    cheers Alex
    The correct belt is 10mm wide with a circumference of 1113mm, which is usualy reflected in the part number and will certainly be marked on the belt. Is that the one you've used, as there are incorrect ones sometimes supplied that are too long?
      thanks Dave
      I never thought to keep the wrapper ,and the writing on the belt doesn't help ,but you have prompted a brain wave ( 1st and only for the year ! ) I went to Tonys ebay and the part number is MW 1113 , HO NO NOT ANOTHER HOMER MOMENT
      Thanks for your time
        I use this lot for all my belts: http://shop.marksman-ind.com/drive-b...ulleys-8-c.asp
        No connection, but their belts are PIX, and they have all sorts of goodies for those who like making stuff, belts, pulleys, chains, sprockets, seals, bearings, shims etc etc.
        James
        sigpic Stag Haulage, Flookburgh
        74 Stag Manual Triumph V8, Loads of other vintage scrap
