Now then all, my new exhaust manifolds are currently on their way to me from phoenix and I'm debating how to fasten then too the heads.
My preferred method is to make some stainless studs to put in the heads and fasten the manifolds on with brass nuts but, I fear if I do this then should I ever have to remove the manifolds when the engine is in the car it will be tight for room to slide the manifolds off the studs, therefore it would be better to just run bolts into the heads???
If anyone has experience with this it would be interesting to hear from you.
My other question is about clearance between the steering shaft. I have a cast type steering shaft fitted, I feel this will need turning down or a steel shaft fitting. Has anyone successfully fitted tubular manifolds with an original cast shaft just by repositioning the steering rack?
Thanks,
James
Thanks,
James
