has anyone tried replacing the bonnet stay with the sort of gas struts you find on a hatchback... reason I hear you ask? to stop the bonnet flapping about in the wind...............
bonnet Strut
Originally posted by alistair260661 View Posthas anyone tried replacing the bonnet stay with the sort of gas struts you find on a hatchback... reason I hear you ask? to stop the bonnet flapping about in the wind...............I only do what the voices in my wife’s head tell me to do!
I'm not a fan of the original as in time it just looks messy . I came up with making it out of stainless it more rigid but still flaps in the wind . I'm thinking will a gas strut guarantee to withstand a gust with such a big area ?
Originally posted by edd View PostHow about a hydraulic remote control operated with two rams as Chris suggests wow that would be fun at a show .
Could a nylon gromit be placed over the end to reduce the amount of slack and / or a second one to reduce the pivot on one side.
David
Originally posted by David Lloyd View PostTill the battery's dead! I once put my jump leads in the boot of my Maserati when it was having battery issues... doh, the boot's electric! Also Maserati related, I had to replace my struts as over time they weakened resulting in the bonnet dropping unexpectedly. Sometime the more complex the component - the more to go wrong.
David
Edd
The gas struts are good but they don't stop binnet slamming shut if it's windy - I have had this happen with the Jaguar (bigger bonnet I know)
The idea of a nylon washer or bobbin shaped wheel wold be good - I rember the Rover P6 with the boot mouthed spare wheel had a similar set up
hopefully this link works to the image of the "Boot Prop"
If you give me a couple of days I will see if I can get some pic's of the set up I have fitted, and the struts that I used if you want them that is, let me know.
As far as I know Dave M was the first one to have them fitted to a stag.
Les.Last edited by les M; 27 January 2015, 18:22.
Some gas struts have a locking function built in, so the bonnet can't slam shut. Usually found on bonnets (Range Rover, Lotus...), not rear hatches. To unlock you first have to extend it a bit further. Which is apparently to difficult for some belgian MOT-testers, who just force the bonnet shut, bending the strut in the process...Lotus Esprit Turbo SE 'Emma'
Triumph Stag 'Blanche' work in progress
