Best carb balancing method
    What's your preferred method of balancing Strombergs. After a tube in the ear all seems fine but I do like the thought of a more accurate gauge . Does the cheap looking gunsons ones work or do I need to invest in something more fancy .
    Edd
    Edd
    I use this type Edd,
    I have a Gunson's one as well which was given to me . It does work but is a bit primitive.
      Wished I had known that last week, you could have done my carbs too
        +1 for Ian's carb balancer, really sensitive.
        Micky
          I did start to worry when you kept showing me that ZF box . I'm sure that visit wasn't my last visit anyway so don't panic
              Cheers guys I have just purchased the one Ian suggested . cheers Ian .
              Edd
                Mk1 ear'ole works for me!
                I set them up by ear then use a Gunsons "Carbalancer" thingy to double check, usually spot on. And yes, the Gunsons thing is very primitive, it only works if you are very careful to hold it plumb vertical.
                  I use the same as Ian too - it is useless for doing the Alvis but for my Stag, Vitesse 2 litre and MGB it works a treat. You can't use it on 2"SUs unless you build the cone up with tape so for E types it is useless (and I use a lot of tape because of it)
                  My "glass" pops out a little too readily but there you go.
                  Will eventually replace the Crypton Synchrocheck that some scrotum stole from my toolbox while I was on holiday years ago, but the current ebay prices on secondhand ones are stupidly high and you never know if they have been dropped and fooked until you get it in the post...
                    I use a Crypton Synchro Check, had it for longer than i can remember, always works well
                    ........ Andy
                    ps. i wasn't responsible for the theft from Russ!
                      And don't forget Im only 5 minutes away
                        Cheers Paul.
                          Cheers Paul.
                          Come on Boy's not fighting, there enough Love to share around
                              im feeling a bit left out in the cold here,is there any more love to share round my way
