I have been using my Stag for months now with the roof up and when bored, have found myself being critical of the car and looking to sort out niggling problems / improvements.
However, I have a rumbling sound coming from the rear of the car at all speeds above say 15mph in any gear. It is road speed related and mainly shows up in 2nd gear. It is there even neutral going along and it most evident on acceleration and deceleration. It feels like a rumble and as if you are going over a rough surface. If I accelerate in 2nd, there is a rhythmic drone which I believe is called mangle.
The prop is a solid type with normal u/j's.
Drive shaft are modified GKN's.
Diff has a reinforced nose cone fitted
Open top you wouldn't hear it. As a driver, you May feel it through the drivers seat.
Can't look at car until the weekend but initial thoughts appreciated
Andrew
Andrew
