puddle & footwell lights not working
    hi puddle lights & footwwell lights not working on my mk1 stag any help advice much appreciated
    cheers ovais
    These are fed by the main 'battery control' fuse (purple wire circuit). If your horns, headlamp flash etc all work, then fuse is OK and fault probably lies with breaks in the wiring connections; maybe the master switch wires have dropped off or miswired?
    (even if the door switches are not working or connected this should not stop all of the lights working).
      If you do a search for this subject JULIAN Leyton has posted a diagram on here in the past
      cheers Glenn
        I had a look at my non functional one night thinking it would be a nice 'after tea' job. I soon realised it was better to throw it back together as its more of a 'rainy weekend' (or two) type of job.
        Joking aside here's a useful thread: http://socforum.com/forum/showthread...ts+explanation
        Possibly what Seaking is referring to.
        James
          All the above works I will look at the connections again
          Cheers Chris
            Wil do
            Thanks Glenn
              James
              Thank you James that's the post I was referring to.
              Cheers Glenn
