Hello again, having successfully found my 1st stag via my search on the forum a few months back, I am now in the process of starting on my list of tasks, and now looking for some help (apologies in advance for all the questions)
The car is a 1978 MK2 with a standard TV8, with electronic ignition, has MOT and drives (or did drive!) OK no major issues at present, but my first problem now is that the car refuses to idle, starting from cold with choke, car will make a reluctant start and then just dies seconds later, on further attempts to start the car refuses to turnover!? shows signs of weak battery. Following charging battery repeat of previous happens. I have tried to hold onto revs to keep running but just fades and stops again
Any ideas.. battery not holding charge? coil fault? or a fuel issue? any suggestions appreciated.
Other non related things I have found while pocking a round, no air intake hose from manifold, do I need one?
Fuel interia switch present but not connected, and no sign of connecter, yet again do I need it?
Having also bought a set of new coolant hoses to be fitted, thinking about getting a header tank, any suggestions? I have seen the threads on Stagweber kit and seems the obvious choice, what about alternative plastic bottle kits or make-up own?
Probably the first of many callouts, and all help appreciated.
Lee
PS> pic of car attached, all in all pleased with the car
Lee
